Ana içeriğe geç
Dell Inspiron 17-5749 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-5749 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 17-5749 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Keyboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 17-5749 Keyboard Replacement: adım 2, 2 resimden 2.
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Dell Inspiron 17-5749 Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Turn the computer over and open the display as far as possible
    • Using a plastic opening tool, release the tabs that secure the keyboard to the palm-rest assembly.
    • Before turning over the keyboard, be careful not to pull the keyboard too far away as it could damage the connected ribbon cables.
  4. Dell Inspiron 17-5749 Keyboard Replacement: adım 4, 1 resimden 1.
    • Carefully turn the keyboard over and place it on the palm rest assembly.
    • Lift the latches and disconnect the keyboard cable and keyboard back-light cable from the system board.
    • Lift the keyboard along with the cables, off the palm-rest assembly and set it aside.
Sonuç
Christopher Tran
1.161 İtibar
12 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 412
