Ana içeriğe geç
Dell Inspiron 17-5749 Optical Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-5749 Optical Drive Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 17-5749 Optical Drive Replacement, Battery: adım 1, 2 resimden 2.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Turn off power to the laptop.
    • Unplug the charging cable from the laptop.
    • Failure to unplug the charging cable could result in damaging the computer or seriously injuring yourself.
    • Wear the anti-static wrist strap or work in an uncarpeted area to prevent static shocks. Shocks may damage the components.
  2. Dell Inspiron 17-5749 Optical Drive Replacement: adım 2, 2 resimden 1. Dell Inspiron 17-5749 Optical Drive Replacement: adım 2, 2 resimden 2.
    • First carefully turn the laptop over so you can access the battery.
    • Switch each of the battery latches to the "unlocked" position.
    • Pull battery upwards by the tab to remove from the laptop.
  3. Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 1. Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 2. Dell Inspiron 17-5749 Optical Drive Replacement, Optical Drive: adım 3, 3 resimden 3.
    • Remove the 5.5mm screw that secures the optical-drive assembly to the computer base
    • Using your fingertips, slide the optical-drive assembly out of the optical drive bay.
  4. Dell Inspiron 17-5749 Optical Drive Replacement: adım 4, 3 resimden 1. Dell Inspiron 17-5749 Optical Drive Replacement: adım 4, 3 resimden 2. Dell Inspiron 17-5749 Optical Drive Replacement: adım 4, 3 resimden 3.
    • This step is only needed if replacing the optical drive.
    • Remove the 2.5mm screw that secures the optical-drive bracket to the optical drive assembly.
    • Remove the optical-drive bracket from the optical-drive assembly.
    • Carefully pull the optical-drive bezel and remove it from the optical drive.
Sonuç
Christopher Tran
1.162 İtibar
12 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 21
Her zaman: 184
