Giriş
This guide will allow you to replace a broken display panel for the Dell Inspiron 17-5755. Please ensure that the battery is removed before performing this replacement.
Neye ihtiyacın var
Open the display of the laptop as far as possible, and locate the tabs which secure the keyboard to the laptop.
Use a Phillips #0 screwdriver to unscrew the two 8mm screws which secure the base cover.
Use a Phillips #0 screwdriver to remove the 3mm screw which secures the optical-drive assembly to the computer base
Turn the computer over and using a plastic opening tool, push the optical-drive assembly out of the optical drive bay.
Afterwards, safely pull the optical-drive assembly out of the optical-drive bay.
Using a Phillips 0 screwdriver, remove the screw (M2 x 3) the power-adapter port to the palm-rest assembly.
Peel off the tape that secures the power-adapter port to the palm-rest assembly.
Bir başkası bu kılavuzu tamamladı.
