Ana içeriğe geç
Dell Inspiron 17-5755 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-5755 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the computer has been shut down, and isn't plugged into an outlet before attempting to remove the battery.
  2. Dell Inspiron 17-5755 Hard Drive Replacement: adım 2, 2 resimden 1. Dell Inspiron 17-5755 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Find the battery release latch on the bottom side of the computer.
    • Slide the latch to the left until you hear a "click". This indicates that the battery has been released.
  3. Dell Inspiron 17-5755 Hard Drive Replacement: adım 3, 1 resimden 1.
    • Safely remove the battery from the laptop.
  4. Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 1. Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 2. Dell Inspiron 17-5755 Hard Drive Replacement, Hard Drive: adım 4, 3 resimden 3.
    • Turn over your laptop and locate the two screws which secure the base cover.
    • Use a Phillips #0 screwdriver to unscrew the 8mm screws which secure the base cover.
  5. Dell Inspiron 17-5755 Hard Drive Replacement: adım 5, 2 resimden 1. Dell Inspiron 17-5755 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Locate the tabs that hold the base cover to the laptop and use a plastic opening tool to gently release the base cover.
  6. Dell Inspiron 17-5755 Hard Drive Replacement: adım 6, 3 resimden 1. Dell Inspiron 17-5755 Hard Drive Replacement: adım 6, 3 resimden 2. Dell Inspiron 17-5755 Hard Drive Replacement: adım 6, 3 resimden 3.
    • Now with the base cover removed, you may lift it off of the laptop and continue.
  7. Dell Inspiron 17-5755 Hard Drive Replacement: adım 7, 3 resimden 1. Dell Inspiron 17-5755 Hard Drive Replacement: adım 7, 3 resimden 2. Dell Inspiron 17-5755 Hard Drive Replacement: adım 7, 3 resimden 3.
    • Locate the hard drive cable, and disconnect it from the laptop by lifting the latch which secures the cable.
  8. Dell Inspiron 17-5755 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the four 8mm screws which secure the hard drive assembly to the laptop.
  9. Dell Inspiron 17-5755 Hard Drive Replacement: adım 9, 3 resimden 1. Dell Inspiron 17-5755 Hard Drive Replacement: adım 9, 3 resimden 2. Dell Inspiron 17-5755 Hard Drive Replacement: adım 9, 3 resimden 3.
    • Carefully remove the hard drive and its assembly from the laptop.
  10. Dell Inspiron 17-5755 Hard Drive Replacement: adım 10, 3 resimden 1. Dell Inspiron 17-5755 Hard Drive Replacement: adım 10, 3 resimden 2. Dell Inspiron 17-5755 Hard Drive Replacement: adım 10, 3 resimden 3.
    • Remove the interposer by grabbing the black portion of the assembly, and pulling it away from the hard drive.
    • Be sure to not remove the interposer by pulling on the cable attached to it.
  11. Dell Inspiron 17-5755 Hard Drive Replacement: adım 11, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the four 4mm screws on either side of the hard drive assembly.
    • These screws are very small. Make sure not to misplace them.
  12. Dell Inspiron 17-5755 Hard Drive Replacement: adım 12, 3 resimden 1. Dell Inspiron 17-5755 Hard Drive Replacement: adım 12, 3 resimden 2. Dell Inspiron 17-5755 Hard Drive Replacement: adım 12, 3 resimden 3.
    • Safely remove the hard drive assembly from the hard drive to complete the process.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jeff
385 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S6-G1, Lacy Spring 2017 USF Tampa, Team S6-G1, Lacy Spring 2017 üyesi
USFT-LACY-S17S6G1
3 Üyeler
5 adet Kılavuz yazıldı
2 Yorum
My question is, the hard drive is this a 7mm, 12mm or 15mm drive bay? I want to put a 4tb in my laptop but those are 15mm size and I can’t find what the size limit of the bay is.
Rachael Strange - Yanıt
I want to put a 4tb harddrive in my laptop.
Those only come in 15mm.
will this drive bay hold 15mm sized drives?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 12
Her zaman: 2,596
