Ana içeriğe geç
Dell Inspiron 17-7737 Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Close the display and turn the computer over.
    • Remove the 5 mm screw on the left-hand side of the battery cover using a Phillips #1 screwdriver.
    • Loosen the captive screw on the right-hand side using a Phillips #1 screwdriver.
  2. Dell Inspiron 17-7737 Hard Disk Drive Replacement: adım 2, 3 resimden 1. Dell Inspiron 17-7737 Hard Disk Drive Replacement: adım 2, 3 resimden 2. Dell Inspiron 17-7737 Hard Disk Drive Replacement: adım 2, 3 resimden 3.
    • Pry out the battery cover from the computer base using an opening tool.
  3. Dell Inspiron 17-7737 Hard Disk Drive Replacement: adım 3, 1 resimden 1.
    • Remove the three screws that secure the battery to the base using a Phillips #1 screwdriver.
  4. Dell Inspiron 17-7737 Hard Disk Drive Replacement: adım 4, 2 resimden 1. Dell Inspiron 17-7737 Hard Disk Drive Replacement: adım 4, 2 resimden 2.
    • Using the adhesive pull tab, pull and lift the battery out of the computer's base.
    • If using any tools to get ahold of the adhesive tab, try not to puncture your battery, as battery acids are extremely toxic to humans.
  5. Dell Inspiron 17-7737 Hard Disk Drive Replacement, Hard Disk Drive: adım 5, 1 resimden 1.
    • Remove the four 2.5 mm hard drive bay screws using a Phillips #1 screwdriver.
  6. Dell Inspiron 17-7737 Hard Disk Drive Replacement: adım 6, 1 resimden 1.
    • Using the pull tab, lift the hard drive assembly off of the body.
  7. Dell Inspiron 17-7737 Hard Disk Drive Replacement: adım 7, 2 resimden 1. Dell Inspiron 17-7737 Hard Disk Drive Replacement: adım 7, 2 resimden 2.
    • Disconnect the hard drive cable and lift it out of the computer case.
  8. Dell Inspiron 17-7737 Hard Disk Drive Replacement: adım 8, 1 resimden 1.
    • Remove a total of four screws that secure the cage to the assembly.
    • There are two screws on either side of the cage.
  9. Dell Inspiron 17-7737 Hard Disk Drive Replacement: adım 9, 1 resimden 1.
    • Using the pull tab, lift the hard drive out of the cage.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mark Batista
457 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 UMass Dartmouth, Team 7-7, Ryckebusch Spring 2023 üyesi
UMASSD-RYCKEBUSCH-S23S7G7
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 23
Her zaman: 221
