Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Disconnect the laptop from the AC adapter and turn off the laptop.
Remove the silver 15mm PH 1 screw that holds the plastic cover in place over the battery.
Remove the 8mm PH 1 screw that holds the plastic cover in place over the battery.
Using the metal jimmy, pry up the first half of the cover.
Apply pressure with your fingertips on top of the cover and drag toward the front of the laptop. This will make the plate slide off exposing the hard drive.
Remove the two black PH1 6mm screws that anchor the battery.
Grab the black tab on the battery with index finger and thumb.
Bir başkası bu kılavuzu tamamladı.
