Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This model of computer has an integrated video card embedded in the Motherboard. If the computer seems to have the issues with a failing video card and it is not the drivers then the whole motherboard must be replaced.
Neye ihtiyacın var
Remove the three black 6mm PH1 screws that anchor the hard drive.
This screw hole will be empty because the 15mm silver screw that holds the plastic cover will anchor the hard drive down when completely reassembled.
Remove all wires and ribbon cables attached to the motherboard.
Some Wires have small black tabs on top of them. Meaning one must grab the tab and pull directly upward, gently.
Some ribbon cables may require the blue opening tool to release the cable's connectors before pulling it out.
Finally, some cables have a plastic head with small notches on the side. Use your hand to gently wiggle this cable side to side to remove.
