Ana içeriğe geç
Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement, Base Cover: adım 1, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement, Base Cover: adım 1, 2 resimden 2.
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: adım 2, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: adım 2, 2 resimden 2.
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: adım 3, 3 resimden 1. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: adım 3, 3 resimden 2. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: adım 3, 3 resimden 3.
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: adım 4, 3 resimden 1. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: adım 4, 3 resimden 2. Dell Inspiron 17" 7786 2-in-1 Base Cover Replacement: adım 4, 3 resimden 3.
    • Carefully remove the base cover from the laptop.
Sonuç
Delia Padilla
564 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022 üyesi
GCC-CLASS-F22S1G3
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 16
Her zaman: 135
