Ana içeriğe geç
Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement, Base Cover: adım 1, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement, Base Cover: adım 1, 2 resimden 2.
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 2, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 2, 2 resimden 2.
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 3, 3 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 3, 3 resimden 2. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 3, 3 resimden 3.
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 4, 3 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 4, 3 resimden 2. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 4, 3 resimden 3.
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement, Wireless Card (NIC): adım 5, 3 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement, Wireless Card (NIC): adım 5, 3 resimden 2. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement, Wireless Card (NIC): adım 5, 3 resimden 3.
    • Remove the screw holding down the small bracket for the wireless card using a Phillips #0 screwdriver.
    • Remove the black wired connection from the port over the black triangle.
    • Remove the wire with the white marking from the port above the white triangle.
    • Pull the Wi-Fi card out of its slot.
  6. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement, Fan: adım 6, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement, Fan: adım 6, 2 resimden 2.
    • Gently remove the I/O cable.
  7. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 7, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 7, 2 resimden 2.
    • Remove the fan cable from the motherboard.
  8. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 8, 1 resimden 1.
    • Remove two 3 mm screws that secure the fan using a Phillips #0 screwdriver.
  9. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 9, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 9, 2 resimden 2.
    • There is a little piece of tape/sticker on the fan that connects it to the heat sink. Gently remove this.
    • Lift the fan off the palm rest assembly.
  10. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement, Heatsink: adım 10, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement, Heatsink: adım 10, 2 resimden 2.
    • Loosen seven 3 mm captive screws securing the heatsink to the motherboard using a Phillips #0 screwdriver.
  11. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 11, 3 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 11, 3 resimden 2. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 11, 3 resimden 3.
    • Lift the heatsink off the motherboard.
  12. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement, Display Assembly: adım 12, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement, Display Assembly: adım 12, 2 resimden 2.
    • Ensure that you have your device opened flat at a 180 degree angle. This will make removal easier.
  13. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 13, 3 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 13, 3 resimden 2. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 13, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Locate the ribbon cables for the assembly on the right hand side marked "MB1" and "MB2."
    • The "MB1" ribbon is locked with a copper/brass colored handle that must be lifted upwards. Then you can remove the ribbon by pulling it away from the socket.
    • The "MB2" ribbon is locked in its socket with a black latch. Using a non-metallic precision tool (such as tweezers) lift the latch and pull away the MB2 cable.
  14. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 14, 1 resimden 1.
    • Remove the two screws holding down the assembly on the right hand area using a Phillips #00 screwdriver.
  15. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 15, 3 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 15, 3 resimden 2. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 15, 3 resimden 3.
    • Remove the screw protecting the endpoints of the NIC cables and NIC chip using a Phillips #0 screwdriver.
    • Gently pull away the cabling from the NIC chip.
    • The wires can be removed without removing the heat sink, though this is not advised if you are not familiar with the layout.
  16. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 16, 1 resimden 1.
    • Remove the two screws holding down the bracket of the assembly on the left hand side using a Phillips #0 screwdriver.
  17. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 17, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Display Assembly Replacement: adım 17, 2 resimden 2.
    • Lift the display assembly upwards away from the palm/main assembly.
Sonuç
Antonio Franco
1.025 İtibar
10 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022 üyesi
GCC-CLASS-F22S1G3
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 25
Her zaman: 294
