Ana içeriğe geç
Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: adım 1, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Base Cover: adım 1, 2 resimden 2.
    • Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
  2. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 2, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 2, 2 resimden 2.
    • Loosen the three captive screws that secure the base closer to the hinges.
    • Do not attempt to remove the three captive screws! You need only to loosen them. They're supposed to stay on the base cover.
  3. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 3, 3 resimden 1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 3, 3 resimden 2. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 3, 3 resimden 3.
    • Carefully pry the base cover using an iFixit opening tool in the crevice near the hinges. Guide the pick along the edges and slightly lift upwards as you go along.
    • Do not start from the speaker end of the edges when opening, or you may cause further damage to your device!
  4. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 4, 3 resimden 1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 4, 3 resimden 2. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 4, 3 resimden 3.
    • Carefully remove the base cover from the laptop.
  5. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: adım 5, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Fan: adım 5, 2 resimden 2.
    • Gently remove the I/O cable.
  6. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 6, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 6, 2 resimden 2.
    • Remove the fan cable from the motherboard.
  7. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 7, 1 resimden 1.
    • Remove two 3 mm screws that secure the fan using a Phillips #0 screwdriver.
  8. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 8, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 8, 2 resimden 2.
    • There is a little piece of tape/sticker on the fan that connects it to the heat sink. Gently remove this.
    • Lift the fan off the palm rest assembly.
  9. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: adım 9, 2 resimden 1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement, Heatsink: adım 9, 2 resimden 2.
    • Loosen seven 3 mm captive screws securing the heatsink to the motherboard using a Phillips #0 screwdriver.
  10. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 10, 3 resimden 1. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 10, 3 resimden 2. Dell Inspiron 17" 7786 2-in-1 Heatsink Replacement: adım 10, 3 resimden 3.
    • Lift the heatsink off the motherboard.
Sonuç
Delia Padilla
564 İtibar
5 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-3, Class Fall 2022 Gateway, Team 1-3, Class Fall 2022 üyesi
GCC-CLASS-F22S1G3
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 66
