Giriş
Possibly one of the only components that can be interchangeable with other devices, if you're looking for a quick replacement. Remember, black wire to black slot, white wire to white slot.
Neye ihtiyacın var
Remove the eight M2 5mm screws that secure the base cover using a Phillips #0 screwdriver.
Remove the screw holding down the small bracket for the wireless card using a Phillips #0 screwdriver.
Remove the black wired connection from the port over the black triangle.
Remove the wire with the white marking from the port above the white triangle.
Pull the Wi-Fi card out of its slot.
