Ana içeriğe geç
Dell Inspiron 1721 DVD Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1721 DVD Drive Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 1721 DVD Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Slide tabs outward to undo the locks.
    • Grab and pull the battery away from the device to remove.
  2. Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: adım 2, 3 resimden 1. Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: adım 2, 3 resimden 2. Dell Inspiron 1721 DVD Drive Replacement, Hinge Plate Cover: adım 2, 3 resimden 3.
    • Pry up on the corner of the hinge cover with an iFixit opening tool.
    • Use the iFixit opening tool along both sides and the front of the hinge cover to release it.
    • Lean the display back as far as it goes and lift up on the hinge cover to remove.
  3. Dell Inspiron 1721 DVD Drive Replacement, Keyboard: adım 3, 3 resimden 1. Dell Inspiron 1721 DVD Drive Replacement, Keyboard: adım 3, 3 resimden 2. Dell Inspiron 1721 DVD Drive Replacement, Keyboard: adım 3, 3 resimden 3.
    • Remove four 3mm Phillips #1 screws from the top of the keyboard.
    • Use an iFixit opening tool to slide the keyboard upwards toward the display.
    • Slide the keyboard until it is clear of the lock tab, and lift it up to remove.
  4. Dell Inspiron 1721 DVD Drive Replacement, Back Cover: adım 4, 1 resimden 1.
    • Disconnect the touch pad connector.
  5. Dell Inspiron 1721 DVD Drive Replacement: adım 5, 3 resimden 1. Dell Inspiron 1721 DVD Drive Replacement: adım 5, 3 resimden 2. Dell Inspiron 1721 DVD Drive Replacement: adım 5, 3 resimden 3.
    • Lay the device flat and remove the 17 7mm Phillips #0 screws.
    • Use an iFixit opening tool to separate the back cover.
    • Remove the back cover.
  6. Dell Inspiron 1721 DVD Drive Replacement, DVD Drive: adım 6, 2 resimden 1. Dell Inspiron 1721 DVD Drive Replacement, DVD Drive: adım 6, 2 resimden 2.
    • Grab the DVD drive and pull straight out from the side of the case to remove.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 15
Her zaman: 186
