Ana içeriğe geç
Dell Inspiron 1750 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1750 Hard Drive Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 1750 Hard Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 Hard Drive Replacement: adım 2, 2 resimden 1. Dell Inspiron 1750 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. Dell Inspiron 1750 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Remove the two 1mm double wide Phillips #00 screws.
    • Pull the hard drive away from the laptop.
  4. Dell Inspiron 1750 Hard Drive Replacement: adım 4, 2 resimden 1. Dell Inspiron 1750 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Keep all screws in a safe place. You may need to use them for your new hard drive.
    • Remove the two #00 1mm screws on both sides of the hard drive.
    • Pull the hard drive cover away from the hard drive and set the cover aside.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tina Rickard
759 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-3, Forte Spring 2014 Cal Poly, Team 6-3, Forte Spring 2014 üyesi
CPSU-FORTE-S14S6G3
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 9,934
