Ana içeriğe geç
Dell Inspiron 1750 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 1750 RAM Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 1750 RAM Replacement, Battery: adım 1, 2 resimden 2.
    • Unplug the laptop before changing the battery to avoid electric shock.
    • Place the laptop on a flat stable surface.
    • Flip the laptop over so the underside is visible.
  2. Dell Inspiron 1750 RAM Replacement: adım 2, 2 resimden 1. Dell Inspiron 1750 RAM Replacement: adım 2, 2 resimden 2.
    • Locate the battery lock switch.
    • Slide the lock switch to the left (away from the lock symbol).
    • Slide the battery out away from the laptop.
  3. Dell Inspiron 1750 RAM Replacement, RAM: adım 3, 3 resimden 1. Dell Inspiron 1750 RAM Replacement, RAM: adım 3, 3 resimden 2. Dell Inspiron 1750 RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Remove the one 2mm Phillips #00 screw on the module cover.
    • Use the plastic opening tool to lift the module cover.
  4. Dell Inspiron 1750 RAM Replacement: adım 4, 2 resimden 1. Dell Inspiron 1750 RAM Replacement: adım 4, 2 resimden 2.
    • Pull the metal tabs away from the RAM chip to release it from the motherboard.
    • Pull the chip up from the laptop.
    • Use the plastic opening tool to lift the chip out if it's difficult to do with your hands.
    • Repeat this process for the RAM chip directly beneath the last one.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Tina Rickard
759 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-3, Forte Spring 2014 Cal Poly, Team 6-3, Forte Spring 2014 üyesi
CPSU-FORTE-S14S6G3
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 1,863
