Giriş
As its name implies, this component provides access to the hard drive and RAM, expediting further repair to the system.
Neye ihtiyacın var
Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
Bir başkası bu kılavuzu tamamladı.
