Giriş
RAM, while integral to a computer’s processing power, is designed to be simple to fix. In practice, most computers (including the Inspiron 17R) feature a system of unplugging used RAM sticks and plugging new ones back in.
Neye ihtiyacın var
Located on the bottom of the laptop’s external shell, there should be two plastic sliding tabs to the right and left of the battery pack. Using your fingers, push these two tabs away from each other, toward the sides of the machine.
Using a Phillips #000 screwdriver, loosen the two screws at the top left and top right of the access door.
Using your fingers, separate the metal tabs located on the left and right of each stick of RAM by pulling them apart from each other.
