Ana içeriğe geç
Dell Inspiron 17R-5737 Access Panel Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17R-5737 Access Panel Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the laptop is off before attempting to remove the battery.
    • Flip over your laptop so that the battery faces you.
  2. Dell Inspiron 17R-5737 Access Panel Replacement: adım 2, 2 resimden 1. Dell Inspiron 17R-5737 Access Panel Replacement: adım 2, 2 resimden 2.
    • Slide each latch away from the battery to unlock it.
  3. Dell Inspiron 17R-5737 Access Panel Replacement: adım 3, 2 resimden 1. Dell Inspiron 17R-5737 Access Panel Replacement: adım 3, 2 resimden 2.
    • Lift the battery upwards to remove it.
    • Continue holding the latches when removing the battery.
  4. Dell Inspiron 17R-5737 Access Panel Replacement, Access Panel: adım 4, 1 resimden 1.
    • Remove two 4.8mm screws with a JIS #00 screwdriver.
    • Remove the access panel.
Sonuç
Mack Chabot
645 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G7, Bailey Fall 2017 UMass Dartmouth, Team S3-G7, Bailey Fall 2017 üyesi
UMASSD-BAILEY-F17S3G7
3 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 354
