Ana içeriğe geç
Dell Inspiron 17R-N7010 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17R-N7010 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Flip over the laptop so the back is facing upwards.
    • Locate the battery compartment.
    • Make sure your laptop is turned off before disassembly.
  2. Dell Inspiron 17R-N7010 Keyboard Replacement: adım 2, 1 resimden 1.
    • Slide both locks away from the center of the battery.
    • After you hear a click, pull out the battery.
  3. Dell Inspiron 17R-N7010 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Remove both screws that connect the keyboard to the laptop chassis.
  4. Dell Inspiron 17R-N7010 Keyboard Replacement: adım 4, 1 resimden 1.
    • Look for the four locks that secure the keyboard on top.
    • Push the lock into the case with a plastic opening tool. It is important to note that each lock has a spring behind it
    • Lift the keyboard up a little bit. A plastic opening tool or nylon spudger can help in lifting the keyboard.
  5. Dell Inspiron 17R-N7010 Keyboard Replacement: adım 5, 1 resimden 1.
    • Lift the top side of the keyboard up and place it upside down. This enables you to access the keyboard cable, which is connected to the motherboard.
    • Lift up the left side of the brown tab with your fingernail and it will open up at 90-degree angle. This will unlock the connector.
    • Unplug the keyboard connector from the motherboard.
    • Remove the keyboard.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 1,335
