Giriş
This guide demonstrates how to replace the motherboard from your Dell Inspiron laptop (model #17R-N7010).
The motherboard is the main circuit board in the computer, which establishes connections between the various components, and allows communication between them.
The motherboard may need replaced if your computer experiences the following issues:
· Frequent screen freezes
· Programs failing to load
· Blue screen of death/ boot failure
· Not recognizing hardware (keyboard, mouse)
· Physical damage to motherboard (burns, chips)
Before beginning this repair, make sure your laptop is turned off and disconnected from the power adapter.
Neye ihtiyacın var
Flip over the laptop so the back is facing upwards.
Locate the battery compartment.
Remove the four screws from the back panel.
Flip the laptop over and open it to view the keyboard.
Disconnect the keyboard from the laptop by lifting up the latch holding the ribbon cable in place.
Carefully unplug the four ports connecting to the computer (the prying tool may come in handy when using it on the ports).
2 farklı kişi bu kılavuzu tamamladı.
