Parçalar
Hiçbir parçaya gerek yok.
  1. Be sure to power off the laptop and remove the battery before proceeding with the disassembly.
    • Be sure to power off the laptop and remove the battery before proceeding with the disassembly.
    • Flip the laptop over and locate the battery compartment on the bottom .
  2. Slide both locks away from the center of the battery.
    • Slide both locks away from the center of the battery.
    • The battery can then be removed after hearing a click.
    • To reinstall the battery, slide the battery back in place until you hear a click.
  3. Be sure to power off the laptop and remove the battery before proceeding with the disassembly. Flip the laptop to the back. Locate and unscrew the four screws highlighted in green. Flip the laptop over and open to the face of the keyboard.
    • Flip the laptop to the back. Locate and unscrew the four screws highlighted in green.
    • Flip the laptop over and open to the face of the keyboard.
    • You will notice the keyboard is connected to the laptop by a thin wire. To disconnect the keyboard, lift up the latch boxed in blue holding the wire in place.
  4. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  5. Flip to the back of the laptop. To remove the back cover, locate and unscrew the screws indicated in green. Next, slide the CD drive out to locate the final screws. Unscrew the three screws highlighted in green.
    • Flip to the back of the laptop. To remove the back cover, locate and unscrew the screws indicated in green.
    • Next, slide the CD drive out to locate the final screws.
    • Unscrew the three screws highlighted in green.
  6. This step may be tricky, and feel like you are breaking the laptop. Following these steps carefully will ensure a safe disassembly of the device without damaging the hardware.
    • This step may be tricky, and feel like you are breaking the laptop. Following these steps carefully will ensure a safe disassembly of the device without damaging the hardware.
    • To safely remove the top cover, grab a spudger and insert it under the grey surface where the blue circle is shown. Make prying motion upwards to detach the locks.
    • Work clockwise starting from the indicated circle; inserting the spudger under the grey cover, and lifting up to detach the locks.
  7. Make sure to disconnect the wires circled in green before completely removing the top cover. After removing the cover, you will now have access to the inner hardware: Mother Board, fans, processors, etc.
    • Make sure to disconnect the wires circled in green before completely removing the top cover.
    • After removing the cover, you will now have access to the inner hardware: Mother Board, fans, processors, etc.
  8. The fan is located at the top left circled in blue. To remove the fan, disconnect the coupled wires from the white port  Highlighted in red. Then disconnect the wire strip by lifting up the latch holding the wire in place also highlighted in red.
    • The fan is located at the top left circled in blue.
    • To remove the fan, disconnect the coupled wires from the white port Highlighted in red.
    • Then disconnect the wire strip by lifting up the latch holding the wire in place also highlighted in red.
    • Finally locate and unscrew the screws circled in pink and remove the fan.
Sonuç
Brandon Lopez
316 İtibar
3 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 12
Her zaman: 55
