Ana içeriğe geç
Dell Inspiron 17R-N7110 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 17R-N7110 Keyboard Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 17R-N7110 Keyboard Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 17R-N7110 Keyboard Replacement, Battery: adım 1, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Do not touch any electronic components without wearing the anti-static wrist strap. Failure to do so poses a risk of static electric shock, and may cause damage to components.
    • Place the laptop on a flat surface with the Dell logo upside down.
    • Flip the laptop over. The battery will be in the top center.
  2. Dell Inspiron 17R-N7110 Keyboard Replacement: adım 2, 2 resimden 1. Dell Inspiron 17R-N7110 Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide both the left lock and right lock, towards the center of the battery.
    • Push upwards on the grip on the bottom of the battery to remove it.
  3. Dell Inspiron 17R-N7110 Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Dell Inspiron 17R-N7110 Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Dell Inspiron 17R-N7110 Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Do not pull the keyboard away from the laptop. The keyboard is connected to the motherboard by a cable. Pulling the keyboard may cause damage to the keyboard and/or motherboard.
    • Metal spudgers and similar prying tools can damage internal components like the motherboard. It is ideal to use a regular black nylon spudger or a plastic opening tool, but for this device the metal jimmy was the only tool to work.
    • Flip over and open your device. Gently wedge the metal Jimmy into the rightmost hole at a 45-degree angle. Make sure that the Jimmy is between the silver metal portion of the keyboard and the silver plastic edge around the keyboard.
    • Tilt the metal jimmy away from you to pry up the edge of the keyboard.
    • Repeat the previous actions on each of the other three holes to release the keyboard.
  4. Dell Inspiron 17R-N7110 Keyboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 17R-N7110 Keyboard Replacement: adım 4, 2 resimden 2.
    • Gently flip the keyboard over and lay it on the touchpad area.
  5. Dell Inspiron 17R-N7110 Keyboard Replacement: adım 5, 3 resimden 1. Dell Inspiron 17R-N7110 Keyboard Replacement: adım 5, 3 resimden 2. Dell Inspiron 17R-N7110 Keyboard Replacement: adım 5, 3 resimden 3.
    • Flip up the black flap where the keyboard cable connects to the motherboard
    • Gently pull the cable away from the slot to release the keyboard.
    • Remove the keyboard from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 1,656
