Ana içeriğe geç
Dell Inspiron 3148 CMOS Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 3148 CMOS Battery Replacement, Back Panel: adım 1, 2 resimden 1. Dell Inspiron 3148 CMOS Battery Replacement, Back Panel: adım 1, 2 resimden 2.
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 CMOS Battery Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 CMOS Battery Replacement: adım 3, 2 resimden 1. Dell Inspiron 3148 CMOS Battery Replacement: adım 3, 2 resimden 2.
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 CMOS Battery Replacement, CMOS Battery: adım 4, 3 resimden 1. Dell Inspiron 3148 CMOS Battery Replacement, CMOS Battery: adım 4, 3 resimden 2. Dell Inspiron 3148 CMOS Battery Replacement, CMOS Battery: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Using a pair of tweezers, lift the exposed edge of the CMOS battery upward.
    • Once the CMOS battery has been loosened, remove it from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Gravelle
837 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 UMass Dartmouth, Team S1-G2, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 20
Her zaman: 272
