Ana içeriğe geç
Dell Inspiron 3148 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 3148 Hard Drive Replacement, Back Panel: adım 1, 2 resimden 1. Dell Inspiron 3148 Hard Drive Replacement, Back Panel: adım 1, 2 resimden 2.
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 Hard Drive Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 Hard Drive Replacement: adım 3, 2 resimden 1. Dell Inspiron 3148 Hard Drive Replacement: adım 3, 2 resimden 2.
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 Hard Drive Replacement, Battery: adım 4, 1 resimden 1.
    • Remove the three 4mm screws holding battery in place using the Phillips #0 screwdriver.
  5. Dell Inspiron 3148 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Using the iFixit opening tools, lift the battery out of its housing.
  6. Dell Inspiron 3148 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Once loosened, use your fingers to lift the battery up and out of its housing.
    • There is a small cable which sits in a rut in the top of the battery. Ensure that it is pushed out of the way before removing completely.
  7. Dell Inspiron 3148 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Remove the battery completely.
  8. Dell Inspiron 3148 Hard Drive Replacement, Hard Drive: adım 8, 3 resimden 1. Dell Inspiron 3148 Hard Drive Replacement, Hard Drive: adım 8, 3 resimden 2. Dell Inspiron 3148 Hard Drive Replacement, Hard Drive: adım 8, 3 resimden 3.
    • If there is a piece of tape connecting the hard drive and a small power cord, remove the tape.
    • Using the Phillips #0 screwdriver, remove the two 4mm screws.
  9. Dell Inspiron 3148 Hard Drive Replacement: adım 9, 3 resimden 1. Dell Inspiron 3148 Hard Drive Replacement: adım 9, 3 resimden 2. Dell Inspiron 3148 Hard Drive Replacement: adım 9, 3 resimden 3.
    • Notice: there is a small data cable connecting the hard drive to the motherboard. Do not attempt to lift the hard drive all the way out before removing this cable.
    • Lift the hard drive slightly out of the device.
    • Grasp the head of the cable, not the cable itself.
    • Pull away from the hard drive, removing the data cable. The hard drive may now be fully removed.
Sonuç
Christopher Gravelle
837 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 UMass Dartmouth, Team S1-G2, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 462
