Ana içeriğe geç
Dell Inspiron 3148 WLAN Card Replacement
Neye ihtiyacın var
  1. Dell Inspiron 3148 WLAN Card Replacement, Back Panel: adım 1, 2 resimden 1. Dell Inspiron 3148 WLAN Card Replacement, Back Panel: adım 1, 2 resimden 2.
    • Ensure the device is powered off and unplugged. Close the device and orient it face up, with the hinges further away from you.
    • Flip the device over so the backside is facing you.
  2. Dell Inspiron 3148 WLAN Card Replacement: adım 2, 1 resimden 1.
    • Using the Phillips #1 screwdriver, remove all nine 7mm screws.
  3. Dell Inspiron 3148 WLAN Card Replacement: adım 3, 2 resimden 1. Dell Inspiron 3148 WLAN Card Replacement: adım 3, 2 resimden 2.
    • Using the plastic opening tool, pull the back panel upward. Move the opening tool along the edge of the device and lift the panel off of your device.
    • Be aware, the back panel is kept in place by magnetic clips. They will offer some resistance, but continue to gently leverage upwards.
  4. Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: adım 4, 3 resimden 1. Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: adım 4, 3 resimden 2. Dell Inspiron 3148 WLAN Card Replacement, WLAN Card: adım 4, 3 resimden 3.
    • Locate the WLAN chip. It is a small wireless network card with two small cables connected to it, one black and one white.
    • Using a Phillips #0 screwdriver, remove the single 2mm screw from the WLAN card.
    • The card should pop right up once the screw is removed.
  5. Dell Inspiron 3148 WLAN Card Replacement: adım 5, 1 resimden 1.
    • Remove the two wires by pulling them upward, away from the WLAN card.
  6. Dell Inspiron 3148 WLAN Card Replacement: adım 6, 2 resimden 1. Dell Inspiron 3148 WLAN Card Replacement: adım 6, 2 resimden 2.
    • Using your fingers, pull the WLAN card up and away from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Christopher Gravelle
837 İtibar
7 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S1-G2, Simcock Fall 2018 UMass Dartmouth, Team S1-G2, Simcock Fall 2018 üyesi
UMASSD-SIMCOCK-F18S1G2
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 287
