Ana içeriğe geç
Dell Inspiron 3520 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 3520 Keyboard Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 3520 Keyboard Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off notebook
    • Set the notebook upside down with the battery facing away from you.
    • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
  2. Dell Inspiron 3520 Keyboard Replacement: adım 2, 3 resimden 1. Dell Inspiron 3520 Keyboard Replacement: adım 2, 3 resimden 2. Dell Inspiron 3520 Keyboard Replacement: adım 2, 3 resimden 3.
    • Slide the right tab to the right to unlock the battery.
    • Slide and hold the the left tab to the left to release the battery from the unit.
    • Finally, remove the battery by sliding it away from the unit and yourself.
  3. Dell Inspiron 3520 Keyboard Replacement, Keyboard: adım 3, 2 resimden 1. Dell Inspiron 3520 Keyboard Replacement, Keyboard: adım 3, 2 resimden 2.
    • Locate the four tabs along the top edge of the keyboard.
    • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
  4. Dell Inspiron 3520 Keyboard Replacement: adım 4, 1 resimden 1.
    • Slide the keyboard forward towards the screen to release the bottom tabs.
  5. Dell Inspiron 3520 Keyboard Replacement: adım 5, 2 resimden 1. Dell Inspiron 3520 Keyboard Replacement: adım 5, 2 resimden 2.
    • Carefully lift the board up and locate the connecting cable.
    • Gently pull the end of the cable free from the port on the laptop.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Ian
1.557 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Watkins Winter 2015 USF Tampa, Team 16-2, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S16G2
3 Üyeler
1Rehber Yorum
Hi, any ideas why a NEW keyboard still wouldn't work after installing it? The ribbon was connected properly, it’s the right keyboard, and I made sure the driver was updated. Any help would be greatly appreciated. Started a new job and my keyboard went to $@$* in the first week. Can’t really afford to buy a new laptop this weekend. It works with an external USB keyboard so it’s probably not a software issue… I think?
Alittle advice would be greatly appreciated. Thanks!
Stumpedu - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 50
Her zaman: 6,406
