Ana içeriğe geç
Dell Inspiron 3520 RAM Replacement
Neye ihtiyacın var
    1. Dell Inspiron 3520 RAM Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 3520 RAM Replacement, Battery: adım 1, 2 resimden 2.
      • Turn off notebook
      • Set the notebook upside down with the battery facing away from you.
      • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 3520 RAM Replacement: adım 2, 3 resimden 1. Dell Inspiron 3520 RAM Replacement: adım 2, 3 resimden 2. Dell Inspiron 3520 RAM Replacement: adım 2, 3 resimden 3.
      • Slide the right tab to the right to unlock the battery.
      • Slide and hold the the left tab to the left to release the battery from the unit.
      • Finally, remove the battery by sliding it away from the unit and yourself.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 3520 RAM Replacement, Keyboard: adım 3, 2 resimden 1. Dell Inspiron 3520 RAM Replacement, Keyboard: adım 3, 2 resimden 2.
      • Locate the four tabs along the top edge of the keyboard.
      • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 3520 RAM Replacement: adım 4, 1 resimden 1.
      • Slide the keyboard forward towards the screen to release the bottom tabs.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 3520 RAM Replacement: adım 5, 2 resimden 1. Dell Inspiron 3520 RAM Replacement: adım 5, 2 resimden 2.
      • Carefully lift the board up and locate the connecting cable.
      • Gently pull the end of the cable free from the port on the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 3520 RAM Replacement, RAM: adım 6, 1 resimden 1.
      • Locate the RAM chip(s)
      • There are no RAM chips present in this photo.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 3520 RAM Replacement: adım 7, 2 resimden 1. Dell Inspiron 3520 RAM Replacement: adım 7, 2 resimden 2.
      • There are two connecting pins for the lower chip.
      • There are two connecting pins for the upper chip.
      • Pull the pins away from the sides of the chip(s) to release it.
      • The chip(s) should slide away from the dock easily.
      FixBot'a Sor
      Yorum Ekle
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Ian
1.638 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Watkins Winter 2015 USF Tampa, Team 16-2, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S16G2
3 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 58
Her zaman: 33,625
