Ana içeriğe geç
Dell Inspiron 3520 Screen Replacement
Neye ihtiyacın var
    1. Dell Inspiron 3520 Screen Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 3520 Screen Replacement, Battery: adım 1, 2 resimden 2.
      • Turn off notebook
      • Set the notebook upside down with the battery facing away from you.
      • Locate the unlock and release sliding tabs on the bottom right and left hand corners of the battery respectively.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 3520 Screen Replacement: adım 2, 3 resimden 1. Dell Inspiron 3520 Screen Replacement: adım 2, 3 resimden 2. Dell Inspiron 3520 Screen Replacement: adım 2, 3 resimden 3.
      • Slide the right tab to the right to unlock the battery.
      • Slide and hold the the left tab to the left to release the battery from the unit.
      • Finally, remove the battery by sliding it away from the unit and yourself.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 3520 Screen Replacement, Keyboard: adım 3, 2 resimden 1. Dell Inspiron 3520 Screen Replacement, Keyboard: adım 3, 2 resimden 2.
      • Locate the four tabs along the top edge of the keyboard.
      • Using the spudger, push the tabs away from the keyboard and pull the keyboard up away from the laptop.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 3520 Screen Replacement: adım 4, 1 resimden 1.
      • Slide the keyboard forward towards the screen to release the bottom tabs.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 3520 Screen Replacement: adım 5, 2 resimden 1. Dell Inspiron 3520 Screen Replacement: adım 5, 2 resimden 2.
      • Carefully lift the board up and locate the connecting cable.
      • Gently pull the end of the cable free from the port on the laptop.
      FixBot'a Sor
      Yorum Ekle
    1. Dell Inspiron 3520 Screen Replacement, Screen: adım 6, 3 resimden 1. Dell Inspiron 3520 Screen Replacement, Screen: adım 6, 3 resimden 2. Dell Inspiron 3520 Screen Replacement, Screen: adım 6, 3 resimden 3.
      • Locate and remove the 14 (5mm) Phillips #00 screws from the bottom of the laptop.
      • Locate and remove the two 5mm Phillips #00 screws found under the keyboard.
      • Disconnect the two controlling wires with the blue pull tabs.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 3520 Screen Replacement: adım 7, 3 resimden 1. Dell Inspiron 3520 Screen Replacement: adım 7, 3 resimden 2. Dell Inspiron 3520 Screen Replacement: adım 7, 3 resimden 3.
      • Using the spudger, carefully work your way around the edge of the upper shell.
      • Lift the upper shell away from the laptop.
      • Close the laptop and remove the casing over the hinge using the spudger.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 3520 Screen Replacement: adım 8, 3 resimden 1. Dell Inspiron 3520 Screen Replacement: adım 8, 3 resimden 2. Dell Inspiron 3520 Screen Replacement: adım 8, 3 resimden 3.
      • Gently pull the cable located near the fan free from its dock.
      • Just behind the optical drive locate the 4mm Phillps #00 mounting screw for the small circuit board and remove it.
      • The board should then pull free.
      • Take note of how the cables fit along the ridge for when it comes to reassembly.
      FixBot'a Sor
      Yorum Ekle
    4. Dell Inspiron 3520 Screen Replacement: adım 9, 2 resimden 1. Dell Inspiron 3520 Screen Replacement: adım 9, 2 resimden 2.
      • Open the laptop and locate the two hinges.
      • Each hinge has two 5mm Phillips #00 screws that need to be removed.
      • With the screws removed the screen should pull free.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Ian
1.638 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-2, Watkins Winter 2015 USF Tampa, Team 16-2, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S16G2
3 Üyeler
15 adet Kılavuz yazıldı
1Rehber Yorum
These instructions are not for screen replacement
Ryan Zulu - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 62
Her zaman: 7,125
