Ana içeriğe geç
Dell Inspiron 3537 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 3537 RAM Replacement, RAM: adım 1, 3 resimden 1. Dell Inspiron 3537 RAM Replacement, RAM: adım 1, 3 resimden 2. Dell Inspiron 3537 RAM Replacement, RAM: adım 1, 3 resimden 3.
    • Use a Phillips #0 screwdriver to loosen the two 3 mm captive screws holding the tray in place.
    • The screws cannot be fully removed and only need to be loosened. Do not attempt to remove the screws from the tray.
    • Lift the RAM tray up and off.
  2. Dell Inspiron 3537 RAM Replacement: adım 2, 3 resimden 1. Dell Inspiron 3537 RAM Replacement: adım 2, 3 resimden 2. Dell Inspiron 3537 RAM Replacement: adım 2, 3 resimden 3.
    • Gently pull the two silver arms away from the RAM until the RAM slightly lifts from the motherboard.
  3. Dell Inspiron 3537 RAM Replacement: adım 3, 2 resimden 1. Dell Inspiron 3537 RAM Replacement: adım 3, 2 resimden 2.
    • Slide the RAM directly out of its slot.
  4. Dell Inspiron 3537 RAM Replacement: adım 4, 3 resimden 1. Dell Inspiron 3537 RAM Replacement: adım 4, 3 resimden 2. Dell Inspiron 3537 RAM Replacement: adım 4, 3 resimden 3.
    • Insert your new/replacement RAM stick(s) into the slot(s).
    • Gently push down on the RAM until it clicks into place.
  5. Dell Inspiron 3537 RAM Replacement: adım 5, 2 resimden 1. Dell Inspiron 3537 RAM Replacement: adım 5, 2 resimden 2.
    • Replace the RAM tray.
    • Screw in the two 3 mm screws with a Phillips #0 screwdriver.
Sonuç
Enjoy your new RAM!
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 17
Her zaman: 806
