Ana içeriğe geç
Dell Inspiron 3542 Heat Sink Replacement
Neye ihtiyacın var
  1. Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: adım 1, 2 resimden 1. Dell Inspiron 3542 Heat Sink Replacement, Heat Sink: adım 1, 2 resimden 2.
    • Slide the latches on both sides of the computer outward to unlock the battery.
    • Remove the battery from the computer.
  2. Dell Inspiron 3542 Heat Sink Replacement: adım 2, 2 resimden 1. Dell Inspiron 3542 Heat Sink Replacement: adım 2, 2 resimden 2.
    • Remove the screw. (1x M2 x 3mm)
    • Slide down the access door and remove it.
  3. Dell Inspiron 3542 Heat Sink Replacement: adım 3, 3 resimden 1. Dell Inspiron 3542 Heat Sink Replacement: adım 3, 3 resimden 2. Dell Inspiron 3542 Heat Sink Replacement: adım 3, 3 resimden 3.
    • Remove the screw. (1 x m2 x 3mm)
    • Move the hard drive to the open area and remove it.
  4. Dell Inspiron 3542 Heat Sink Replacement: adım 4, 3 resimden 1. Dell Inspiron 3542 Heat Sink Replacement: adım 4, 3 resimden 2. Dell Inspiron 3542 Heat Sink Replacement: adım 4, 3 resimden 3.
    • Unplug the black and white antenna cables from the wireless card.
    • Remove the screw. (1 x M2 x 3mm)
    • Remove the wireless card from the laptop.
  5. Dell Inspiron 3542 Heat Sink Replacement: adım 5, 3 resimden 1. Dell Inspiron 3542 Heat Sink Replacement: adım 5, 3 resimden 2. Dell Inspiron 3542 Heat Sink Replacement: adım 5, 3 resimden 3.
    • Turn over the laptop and open it.
    • Use the plastic prying device to release the keyboard.
    • Lift the keyboard.
    • Unplug the cable connecting the keyboard to the laptop.
    • Remove the keyboard.
    • Remove the screws. (3 x M2.5 x 5mm)
  6. Dell Inspiron 3542 Heat Sink Replacement: adım 6, 2 resimden 1. Dell Inspiron 3542 Heat Sink Replacement: adım 6, 2 resimden 2.
    • Unplug the touch pad cables located on the palm rest.
  7. Dell Inspiron 3542 Heat Sink Replacement: adım 7, 3 resimden 1. Dell Inspiron 3542 Heat Sink Replacement: adım 7, 3 resimden 2. Dell Inspiron 3542 Heat Sink Replacement: adım 7, 3 resimden 3.
    • Carefully unsnap the palm rest from the rest of the laptop.
    • Remove the palm rest.
  8. Dell Inspiron 3542 Heat Sink Replacement: adım 8, 1 resimden 1.
    • Unplug the cable that connects to the motherboard.
    • Remove the DC jack from the laptop.
  9. Dell Inspiron 3542 Heat Sink Replacement: adım 9, 1 resimden 1.
    • Loosen the cables on the antenna.
  10. Dell Inspiron 3542 Heat Sink Replacement: adım 10, 1 resimden 1.
    • Remove the screws. (1 x M2 x 3mm)
    • Unplug the circuit board from the rest of the computer.
  11. Dell Inspiron 3542 Heat Sink Replacement: adım 11, 2 resimden 1. Dell Inspiron 3542 Heat Sink Replacement: adım 11, 2 resimden 2.
    • Loosen the tape on the left side of the laptop.
    • Unplug the display cable.
  12. Dell Inspiron 3542 Heat Sink Replacement: adım 12, 3 resimden 1. Dell Inspiron 3542 Heat Sink Replacement: adım 12, 3 resimden 2. Dell Inspiron 3542 Heat Sink Replacement: adım 12, 3 resimden 3.
    • Unplug the cable on the bottom part of the mother board.
    • Remove the motherboard from the laptop.
  13. Dell Inspiron 3542 Heat Sink Replacement: adım 13, 3 resimden 1. Dell Inspiron 3542 Heat Sink Replacement: adım 13, 3 resimden 2. Dell Inspiron 3542 Heat Sink Replacement: adım 13, 3 resimden 3.
    • Turn over the motherboard.
    • Unplug the cooling fan.
    • Loosen the 3 screws from the heat sink.
    • Remove the heat sink.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Rachel lindsey
733 İtibar
5 adet Kılavuz yazıldı
Ekip
Texas Tech, Team S46-G1, Bennett Spring 2017 Texas Tech, Team S46-G1, Bennett Spring 2017 üyesi
TTU-BENNETT-S17S46G1
3 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 21
Son 30 gün: 31
Her zaman: 1,516
