Ana içeriğe geç
Dell Inspiron 5100 (2015) Thermal Paste Replacement
Neye ihtiyacın var
  1. Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: adım 1, 3 resimden 1. Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: adım 1, 3 resimden 2. Dell Inspiron 5100 (2015) Thermal Paste Replacement, Thermal Paste: adım 1, 3 resimden 3.
    • Use the slider to release and remove the battery.
    • Remove the 11 screws using a small tip Phillips screwdriver.
  2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 2, 3 resimden 1. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 2, 3 resimden 2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 2, 3 resimden 3.
    • Use a flat screw driver to pry against the angled metal.
    • Remove the 3 small screws that were under the optical drive using a small tip Phillips screwdriver.
  3. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 3, 3 resimden 1. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 3, 3 resimden 2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 3, 3 resimden 3.
    • Use a small flat-head screwdriver to pry up at each point indicated to unclip the keyboard from the chassis.
    • Lift the keyboard 2-3 inches up and carefully disconnect the two ribbon cables by unlatching the mechanism and carefully sliding the cable out horizontally.
    • Place the keyboard to the side.
  4. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 4, 3 resimden 1. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 4, 3 resimden 2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 4, 3 resimden 3.
    • Remove the 5 screws using the small Phillips screwdriver.
  5. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 5, 3 resimden 1. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 5, 3 resimden 2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 5, 3 resimden 3.
    • Grab the bottom panel where the optical drive was and lift straight up.
    • It should start popping clips and then come off without much force required.
    • Pay special attention to not break any plastic clips.
  6. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 6, 3 resimden 1. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 6, 3 resimden 2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 6, 3 resimden 3.
    • Loosen the screws one at a time and repeat until they are fully unscrewed.
    • Unplug the fan cable from the header by sliding it out horizontally.
    • Lift the cooler off the CPU with one hand on the CPU area and one hand on the fan assembly.
  7. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 7, 3 resimden 1. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 7, 3 resimden 2. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 7, 3 resimden 3.
    • Using paper towels, q-tips, and isopropyl alcohol, clean off the old thermal paste on the CPU and heatsink.
    • Be careful around the CPU; it is delicate and can be damaged.
  8. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 8, 2 resimden 1. Dell Inspiron 5100 (2015) Thermal Paste Replacement: adım 8, 2 resimden 2.
    • Apply a grain of rice amount of thermal paste to the CPU in the indicated spots.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Dominic Treadwell
184 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 22
Her zaman: 164
