Ana içeriğe geç
Dell Inspiron 5100 PP07L Memory Replacement
Neye ihtiyacın var
  1. Dell Inspiron 5100 PP07L Memory Replacement, Revealing the memory panel: adım 1, 1 resimden 1.
    • Flip the laptop on it's back, so that the bottom is facing up.
  2. Dell Inspiron 5100 PP07L Memory Replacement, Screw Removal: adım 2, 1 resimden 1.
    • Loosen the single Phillips #1 screw.
    • This screw is attached to the panel and cannot be removed.
  3. Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: adım 3, 3 resimden 1. Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: adım 3, 3 resimden 2. Dell Inspiron 5100 PP07L Memory Replacement, Replacing the RAM: adım 3, 3 resimden 3.
    • Push the highlighted pin outward until the RAM pops slightly out of its socket.
    • Place the new chip in at a slight angle, and push it in and downward until little or none of the gold contacts are visible.
    • Not seating the new DIMMs correctly could cause the device to refuse to POST.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
May Chauvin
201 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-34, Maness Spring 2011 Cal Poly, Team 12-34, Maness Spring 2011 üyesi
CPSU-MANESS-S11S12G34
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 4,519
