Ana içeriğe geç
Dell Inspiron 530 CD/DVD Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 530 CD/DVD Drive Replacement, Side Panel: adım 1, 1 resimden 1.
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Dell Inspiron 530 CD/DVD Drive Replacement: adım 2, 1 resimden 1.
    • Slide the side panel towards the back and remove.
  3. Dell Inspiron 530 CD/DVD Drive Replacement, CD/DVD Drive: adım 3, 1 resimden 1.
    • Locate the CD/DVD drive in the upper-front corner of the case.
  4. Dell Inspiron 530 CD/DVD Drive Replacement: adım 4, 1 resimden 1.
    • Locate and remove the two cables attached to the CD/DVD drive.
  5. Dell Inspiron 530 CD/DVD Drive Replacement: adım 5, 1 resimden 1.
    • Locate and remove the two Phillips #0 7.8 mm screws.
  6. Dell Inspiron 530 CD/DVD Drive Replacement: adım 6, 1 resimden 1.
    • Locate the three plastic tabs connecting the computer's faceplate to the case.
    • Gently lift the three tabs to pull off the faceplate.
  7. Dell Inspiron 530 CD/DVD Drive Replacement: adım 7, 1 resimden 1.
    • Pull the faceplate forward and out.
  8. Dell Inspiron 530 CD/DVD Drive Replacement: adım 8, 1 resimden 1.
    • Completely remove the faceplate.
    • Remove the CD/DVD drive by pulling it forward towards the front.
Sonuç
18 farklı kişi bu kılavuzu tamamladı.
Doug Howe
2.221 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-8, Regan Fall 2011 Cal Poly, Team 6-8, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G8
4 Üyeler
18 adet Kılavuz yazıldı
1Rehber Yorum
add the problems may happen and ther solution
mersen getu - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 18
Son 30 gün: 79
Her zaman: 17,841
