Ana içeriğe geç
Dell Inspiron 530 DCMF Bios Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 530 DCMF Bios Battery Replacement, Bios Battery: adım 1, 2 resimden 1. Dell Inspiron 530 DCMF Bios Battery Replacement, Bios Battery: adım 1, 2 resimden 2.
    • Unscrew the two highlighted screws in this image
    • Slide the side panel toward the back of the computer to open the case and access the internals of the device.
  2. Dell Inspiron 530 DCMF Bios Battery Replacement: adım 2, 3 resimden 1. Dell Inspiron 530 DCMF Bios Battery Replacement: adım 2, 3 resimden 2. Dell Inspiron 530 DCMF Bios Battery Replacement: adım 2, 3 resimden 3.
    • The CMOS battery has to be removed properly to avoid damaging the motherboard.
    • Using either your fingers or a spudger, press the small metal tab securing the battery to remove it.
    • Insert a new battery, reattach the side panel, and you've successfully replaced the BIOS battery.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Drew Cunningham
656 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 5-1, Kish Spring 2015 UMass Dartmouth, Team 5-1, Kish Spring 2015 üyesi
UMASSD-KISH-S15S5G1
5 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 32
Her zaman: 5,604
