Ana içeriğe geç
Dell Inspiron 530 Power Supply Replacement
Neye ihtiyacın var
  1. Dell Inspiron 530 Power Supply Replacement, Side Panel: adım 1, 1 resimden 1.
    • Place the case on its side.
    • Locate and remove the two 13.1 mm thumbscrews.
  2. Dell Inspiron 530 Power Supply Replacement: adım 2, 1 resimden 1.
    • Slide the side panel towards the back and remove.
  3. Dell Inspiron 530 Power Supply Replacement, Power Supply: adım 3, 1 resimden 1.
    • Locate the power supply in upper-back corner of the case.
  4. Dell Inspiron 530 Power Supply Replacement: adım 4, 1 resimden 1.
    • Remove the two power cables from the motherboard.
  5. Dell Inspiron 530 Power Supply Replacement: adım 5, 1 resimden 1.
    • Remove the power cables from the CD/DVD drive and hard drive.
  6. Dell Inspiron 530 Power Supply Replacement: adım 6, 1 resimden 1.
    • Locate and remove the four Philips #0 8.9 mm screws on the outside of the case.
  7. Dell Inspiron 530 Power Supply Replacement: adım 7, 1 resimden 1.
    • Gently remove the power supply from the case.
Sonuç
17 farklı kişi bu kılavuzu tamamladı.
Doug Howe
2.185 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-8, Regan Fall 2011 Cal Poly, Team 6-8, Regan Fall 2011 üyesi
CPSU-REGAN-F11S6G8
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
Cuantos Watts de una Power Supply la Inspiron 530 soporta?
Baldwin E. C. Rafael - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 44
Her zaman: 26,518
