Ana içeriğe geç
Dell Inspiron 5379 Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 5379 Hard Drive Replacement, Peeling the Tape: adım 1, 1 resimden 1.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • CAUTION: Hard drives are fragile. Exercise care when handling the hard drive.
    • Peel off the tape that secures the hard-drive cable to the palm-rest assembly.
  2. Dell Inspiron 5379 Hard Drive Replacement, Disconnecting the Hard Drive Cable: adım 2, 1 resimden 1.
    • Using the pull tab, disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 5379 Hard Drive Replacement, Remove the Screws: adım 3, 1 resimden 1.
    • Remove the two screws (M2x3.5) that secure the hard-drive assembly to the palm-rest assembly.
  4. Dell Inspiron 5379 Hard Drive Replacement, Lifting the Hard-Drive Assembly: adım 4, 1 resimden 1.
    • Lift the hard-drive assembly, along with its cable, off the palm-rest assembly.
  5. Dell Inspiron 5379 Hard Drive Replacement, Disconnecting the Interposer: adım 5, 1 resimden 1.
    • Disconnect the interposer from the hard-drive assembly.
  6. Dell Inspiron 5379 Hard Drive Replacement, Remove the Screws: adım 6, 1 resimden 1.
    • Remove the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  7. Dell Inspiron 5379 Hard Drive Replacement, Lifting the Hard-Drive Bracket: adım 7, 2 resimden 1. Dell Inspiron 5379 Hard Drive Replacement, Lifting the Hard-Drive Bracket: adım 7, 2 resimden 2.
    • Lift the hard-drive bracket off the hard drive.
  8. Dell Inspiron 5379 Hard Drive Replacement, Align the Screw Holes: adım 8, 1 resimden 1.
    • Align the screw holes on the NEW hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 5379 Hard Drive Replacement, Replace the Screws: adım 9, 1 resimden 1.
    • Replace the four screws (M3x3) that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 5379 Hard Drive Replacement, Connecting the Interposer: adım 10, 1 resimden 1.
    • Connect the interposer to the hard-drive assembly.
  11. Dell Inspiron 5379 Hard Drive Replacement, Align the Screw Holes: adım 11, 1 resimden 1.
    • Align the screw holes on the hard-drive assembly with the screw holes on the palm-rest assembly.
  12. Dell Inspiron 5379 Hard Drive Replacement, Replace the Screws: adım 12, 1 resimden 1.
    • Replace the two screws (M2x3.5) that secure the hard-drive assembly to the palm-rest assembly.
  13. Dell Inspiron 5379 Hard Drive Replacement, Connecting the Hard-Drive Cable: adım 13, 1 resimden 1.
    • Connect the hard-drive cable to the system board.
  14. Dell Inspiron 5379 Hard Drive Replacement, Adhering the Tape: adım 14, 1 resimden 1.
    • Adhere the tape that secures the hard-drive cable to the palm-rest assembly.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
Terrence15
79.243 İtibar
441 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
42 Üyeler
1.989 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 2,089
