Ana içeriğe geç
Dell Inspiron 5555 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 5555 Keyboard  Replacement, Battery: adım 1, 1 resimden 1.
    • Close the laptop and lay it flat, logo side down.
    • Make sure that the battery is visible and at the top of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 5555 Keyboard  Replacement: adım 2, 3 resimden 1. Dell Inspiron 5555 Keyboard  Replacement: adım 2, 3 resimden 2. Dell Inspiron 5555 Keyboard  Replacement: adım 2, 3 resimden 3.
    • Push the lock switch to the left to pop out the battery.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 5555 Keyboard  Replacement: adım 3, 3 resimden 1. Dell Inspiron 5555 Keyboard  Replacement: adım 3, 3 resimden 2. Dell Inspiron 5555 Keyboard  Replacement: adım 3, 3 resimden 3.
    • When the battery pops out, lift it so that it comes out completely.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 5555 Keyboard  Replacement, Keyboard: adım 4, 3 resimden 1. Dell Inspiron 5555 Keyboard  Replacement, Keyboard: adım 4, 3 resimden 2. Dell Inspiron 5555 Keyboard  Replacement, Keyboard: adım 4, 3 resimden 3.
    • Turn the laptop over and open the device.
    • Insert the flat end of the spudger into the five notches located at the top of the keyboard and pry the keyboard up by pushing down and up.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Inspiron 5555 Keyboard  Replacement: adım 5, 2 resimden 1. Dell Inspiron 5555 Keyboard  Replacement: adım 5, 2 resimden 2.
    • Lift up and slide back to release the six notches from the bottom of the keyboard.
    • Be careful not to lift the keyboard up all the way because it is still connected to the laptop by a cable on the bottom.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Inspiron 5555 Keyboard  Replacement: adım 6, 3 resimden 1. Dell Inspiron 5555 Keyboard  Replacement: adım 6, 3 resimden 2. Dell Inspiron 5555 Keyboard  Replacement: adım 6, 3 resimden 3.
    • Flip the keyboard upside down to access the keyboard cable.
    • Using the flat end of the spudger, flip the black tab securing the keyboard cable up to remove the keyboard cable.
    • Remove the keyboard by lifting it off of the laptop.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Thank you so much for this guide! The steps were clear and concise.
Scott Kerman - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 13
Son 30 gün: 35
Her zaman: 1,205
