Ana içeriğe geç
Dell Inspiron 5680 RAM Replacement
Neye ihtiyacın var
  1. Dell Inspiron 5680 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Power off and unplug the power cable from the computer.
    • You may want to unplug all of the cables and lay the computer on its side to make it easier to work on.
  2. Dell Inspiron 5680 RAM Replacement: adım 2, 2 resimden 1. Dell Inspiron 5680 RAM Replacement: adım 2, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove two screws on the side panel of your computer.
  3. Dell Inspiron 5680 RAM Replacement: adım 3, 3 resimden 1. Dell Inspiron 5680 RAM Replacement: adım 3, 3 resimden 2. Dell Inspiron 5680 RAM Replacement: adım 3, 3 resimden 3.
    • Remove the side panel from the computer by gently pulling it away from the front of the case and then towards you.
  4. Dell Inspiron 5680 RAM Replacement: adım 4, 3 resimden 1. Dell Inspiron 5680 RAM Replacement: adım 4, 3 resimden 2. Dell Inspiron 5680 RAM Replacement: adım 4, 3 resimden 3.
    • Remove the RAM sticks at the right of the CPU by pressing down on the tabs on both ends of the slot.
  5. Dell Inspiron 5680 RAM Replacement: adım 5, 2 resimden 1. Dell Inspiron 5680 RAM Replacement: adım 5, 2 resimden 2.
    • Take your new RAM sticks and line them up with the slots. Push down until the tabs lock and hold them in place.
    • Do not be afraid to apply a little bit of force here. It is recommended to place the RAM in slots 2 and 4 if you only have two sticks.
  6. Dell Inspiron 5680 RAM Replacement: adım 6, 3 resimden 1. Dell Inspiron 5680 RAM Replacement: adım 6, 3 resimden 2. Dell Inspiron 5680 RAM Replacement: adım 6, 3 resimden 3.
    • Put the side panel back on, plug the computer in and power it on. You have successful installed your RAM and your computer is ready to run faster.
Sonuç
If your computer does not power on you have not installed the RAM properly. Revisit step 5 and make sure the RAM is completely pushed into the slots.
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 1,565
