Giriş
This guide is to replace the DC Jack in a Dell Inspiron 5758 laptop. Ensure you have all replacement parts and tools needed for this step-by-step replacement guide.
Neye ihtiyacın var
Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
Remove the one 3mm optical drive screw.
Remove the two 8 mm screws.
Pry up and remove the access door.
Bir başkası bu kılavuzu tamamladı.
