Ana içeriğe geç
Dell Inspiron 5758 DC Jack Replacement
Neye ihtiyacın var
  1. Dell Inspiron 5758 DC Jack Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 5758 DC Jack Replacement, Battery: adım 1, 2 resimden 2.
    • Flip the laptop with the serial number facing up. You should be able to see the battery release switch.
  2. Dell Inspiron 5758 DC Jack Replacement: adım 2, 3 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 2, 3 resimden 2. Dell Inspiron 5758 DC Jack Replacement: adım 2, 3 resimden 3.
    • Slide the battery release switch towards the unlock icon.
    • You should hear a click.
    • Lift and pull the ejected battery to remove it.
  3. Dell Inspiron 5758 DC Jack Replacement, DC Jack: adım 3, 3 resimden 1. Dell Inspiron 5758 DC Jack Replacement, DC Jack: adım 3, 3 resimden 2. Dell Inspiron 5758 DC Jack Replacement, DC Jack: adım 3, 3 resimden 3.
    • Remove the one 3mm optical drive screw.
    • Remove the two 8 mm screws.
    • Pry up and remove the access door.
  4. Dell Inspiron 5758 DC Jack Replacement: adım 4, 1 resimden 1.
    • Remove the one 3 mm screw.
    • Remove the bracket.
  5. Dell Inspiron 5758 DC Jack Replacement: adım 5, 2 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 5, 2 resimden 2.
    • Unplug the antenna cables.
    • Remove the Wireless Card.
  6. Dell Inspiron 5758 DC Jack Replacement: adım 6, 2 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 6, 2 resimden 2.
    • Unplug the hard drive cable.
    • Use a plastic opening tool or your fingernail to pop the tab of the cable connector. Then you will be able to disconnect the cable.
    • Remove the four 8 mm screws.
    • Remove the hard drive.
  7. Dell Inspiron 5758 DC Jack Replacement: adım 7, 3 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 7, 3 resimden 2. Dell Inspiron 5758 DC Jack Replacement: adım 7, 3 resimden 3.
    • Remove the two 3 mm screws under the battery.
    • Remove the three 2 mm wafer screws under the optical drive.
    • Remove the ten 8 mm base screws.
  8. Dell Inspiron 5758 DC Jack Replacement: adım 8, 1 resimden 1.
    • Unplug the speaker cable by sliding to the right.
  9. Dell Inspiron 5758 DC Jack Replacement: adım 9, 2 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 9, 2 resimden 2.
    • Press in the tabs to loosen the keyboard.
    • Carefully lift the keyboard up and turn it over.
  10. Dell Inspiron 5758 DC Jack Replacement: adım 10, 1 resimden 1.
    • Unplug the keyboard cable & remove the keyboard.
  11. Dell Inspiron 5758 DC Jack Replacement: adım 11, 2 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 11, 2 resimden 2.
    • Slide the DVD optical drive over & remove it from the laptop.
  12. Dell Inspiron 5758 DC Jack Replacement: adım 12, 2 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 12, 2 resimden 2.
    • Remove the four 5 mm screws.
    • Unplug the optical drive interposer cable.
  13. Dell Inspiron 5758 DC Jack Replacement: adım 13, 2 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 13, 2 resimden 2.
    • Unplug the power button cable.
    • Unplug the touchpad cable.
  14. Dell Inspiron 5758 DC Jack Replacement: adım 14, 3 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 14, 3 resimden 2. Dell Inspiron 5758 DC Jack Replacement: adım 14, 3 resimden 3.
    • Carefully pry off & loosen the bottom base.
  15. Dell Inspiron 5758 DC Jack Replacement: adım 15, 1 resimden 1.
    • Remove the bottom base.
  16. Dell Inspiron 5758 DC Jack Replacement: adım 16, 2 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 16, 2 resimden 2.
    • Remove the one 5mm screw.
    • Lift the circuit board & turn it over.
    • Unplug the cable.
    • Remove the audio/USB circuit board.
  17. Dell Inspiron 5758 DC Jack Replacement: adım 17, 3 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 17, 3 resimden 2. Dell Inspiron 5758 DC Jack Replacement: adım 17, 3 resimden 3.
    • Loosen the audio / USB cable.
    • Remove the one 3mm motherboard screw.
    • Lift the motherboard & carefully move it out of the way.
  18. Dell Inspiron 5758 DC Jack Replacement: adım 18, 3 resimden 1. Dell Inspiron 5758 DC Jack Replacement: adım 18, 3 resimden 2. Dell Inspiron 5758 DC Jack Replacement: adım 18, 3 resimden 3.
    • Unplug the DC jack cable.
    • Remove the one 3mm screw.
    • Remove the DC Jack.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 27
Her zaman: 1,087
