Ana içeriğe geç
Dell Inspiron 6000 DVD/CD Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 6000 DVD/CD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 DVD/CD Drive Replacement: adım 2, 1 resimden 1.
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 DVD/CD Drive Replacement, Removing the DVD/CD Drive Screw: adım 3, 1 resimden 1.
    • Remove one 4mm Philips #00 screw.
  4. Dell Inspiron 6000 DVD/CD Drive Replacement, Inserting Paper Clip: adım 4, 1 resimden 1.
    • Open the paperclip as seen here.
    • Insert the paper clip into small hole next to the eject button on the disk drive.
  5. Dell Inspiron 6000 DVD/CD Drive Replacement, Popping Out the DVD/CD Drive: adım 5, 1 resimden 1.
    • With slight pressure, push the paperclip into the laptop.
    • The disk drive will slowly "pop out" of the side of the laptop.
  6. Dell Inspiron 6000 DVD/CD Drive Replacement, Completely removing the DVD/CD Drive: adım 6, 1 resimden 1.
    • Using your hand, pull the disk drive out of the laptop.
Sonuç
Kenneth Odum
545 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-1, Blackwell Fall 2014 USF Tampa, Team 11-1, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S11G1
5 Üyeler
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,843
