Ana içeriğe geç
Dell Inspiron 6000 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 6000 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 6000 Keyboard Replacement: adım 2, 1 resimden 1.
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 6000 Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Dell Inspiron 6000 Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Dell Inspiron 6000 Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 6000 Keyboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 6000 Keyboard Replacement: adım 4, 2 resimden 2.
    • Remove two 4 mm Philips #00 screws.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Inspiron 6000 Keyboard Replacement: adım 5, 1 resimden 1.
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Inspiron 6000 Keyboard Replacement: adım 6, 3 resimden 1. Dell Inspiron 6000 Keyboard Replacement: adım 6, 3 resimden 2. Dell Inspiron 6000 Keyboard Replacement: adım 6, 3 resimden 3.
    • Gently pull the blue tab up until it comes away from computer.
    FixBot'a Sor
    Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jacob DeWar
563 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-1, Blackwell Fall 2014 USF Tampa, Team 11-1, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S11G1
5 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
Hi there, my dell inspiron 6000 does not power up when I switch on. This happened after I remove my keypad to clean.. Any idea why?
John KAPA - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 36
Her zaman: 2,610
