Ana içeriğe geç
Dell Inspiron 6000 Keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 6000 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
  2. Dell Inspiron 6000 Keyboard Replacement: adım 2, 1 resimden 1.
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
  3. Dell Inspiron 6000 Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Dell Inspiron 6000 Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Dell Inspiron 6000 Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
  4. Dell Inspiron 6000 Keyboard Replacement: adım 4, 2 resimden 1. Dell Inspiron 6000 Keyboard Replacement: adım 4, 2 resimden 2.
    • Remove two 4 mm Philips #00 screws.
  5. Dell Inspiron 6000 Keyboard Replacement: adım 5, 1 resimden 1.
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
  6. Dell Inspiron 6000 Keyboard Replacement: adım 6, 3 resimden 1. Dell Inspiron 6000 Keyboard Replacement: adım 6, 3 resimden 2. Dell Inspiron 6000 Keyboard Replacement: adım 6, 3 resimden 3.
    • Gently pull the blue tab up until it comes away from computer.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jacob DeWar
533 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-1, Blackwell Fall 2014 USF Tampa, Team 11-1, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S11G1
5 Üyeler
7 adet Kılavuz yazıldı
Bir Yorum
Hi there, my dell inspiron 6000 does not power up when I switch on. This happened after I remove my keypad to clean.. Any idea why?
John KAPA - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 17
Her zaman: 2,089
