Ana içeriğe geç
Dell Inspiron 6000 Screen Replacement
Neye ihtiyacın var
  1. Dell Inspiron 6000 Screen Replacement, Battery: adım 1, 1 resimden 1.
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Flip the laptop over, bottom-side up.
    FixBot'a Sor
    Yorum Ekle
  2. Dell Inspiron 6000 Screen Replacement: adım 2, 1 resimden 1.
    • Push the switch next to the battery.
    • At the same time, lift the battery away from the laptop.
    FixBot'a Sor
    Yorum Ekle
  3. Dell Inspiron 6000 Screen Replacement, Keyboard: adım 3, 3 resimden 1. Dell Inspiron 6000 Screen Replacement, Keyboard: adım 3, 3 resimden 2. Dell Inspiron 6000 Screen Replacement, Keyboard: adım 3, 3 resimden 3.
    • Place the laptop on flat surface.
    • Carefully open the laptop at far as it will go so that the back of screen is touching the flat surface.
    • Carefully take a spudger and separate part of the cover at the red circle.
    FixBot'a Sor
    Yorum Ekle
  4. Dell Inspiron 6000 Screen Replacement: adım 4, 2 resimden 1. Dell Inspiron 6000 Screen Replacement: adım 4, 2 resimden 2.
    • Remove two 4 mm Philips #00 screws.
    FixBot'a Sor
    Yorum Ekle
  5. Dell Inspiron 6000 Screen Replacement: adım 5, 1 resimden 1.
    • Gently lift the keyboard away from the laptop without harming the cord that is located at the bottom of the keyboard.
    FixBot'a Sor
    Yorum Ekle
  6. Dell Inspiron 6000 Screen Replacement: adım 6, 3 resimden 1. Dell Inspiron 6000 Screen Replacement: adım 6, 3 resimden 2. Dell Inspiron 6000 Screen Replacement: adım 6, 3 resimden 3.
    • Gently pull the blue tab up until it comes away from computer.
    FixBot'a Sor
    Yorum Ekle
  7. Dell Inspiron 6000 Screen Replacement, Screen: adım 7, 1 resimden 1.
    • Remove one 4mm Philips #00 screw to completely disengage blue tab.
    FixBot'a Sor
    Yorum Ekle
  8. Dell Inspiron 6000 Screen Replacement: adım 8, 1 resimden 1.
    • Pull and disconnect the blue tab.
    FixBot'a Sor
    Yorum Ekle
  9. Dell Inspiron 6000 Screen Replacement: adım 9, 1 resimden 1.
    • Disconnect the black and white wires.
    FixBot'a Sor
    Yorum Ekle
  10. Dell Inspiron 6000 Screen Replacement: adım 10, 1 resimden 1.
    • Remove four 4mm Philips #00 screws at the hinges for the screen.
    FixBot'a Sor
    Yorum Ekle
  11. Dell Inspiron 6000 Screen Replacement: adım 11, 1 resimden 1.
    • Separate the top panel of the laptop from the bottom panel.
    FixBot'a Sor
    Yorum Ekle
  12. Dell Inspiron 6000 Screen Replacement: adım 12, 2 resimden 1. Dell Inspiron 6000 Screen Replacement: adım 12, 2 resimden 2.
    • Use the plastic opening tools to remove the six rubber screw covers in the corners.
    • Remove six 4 mm #00 Philips screws located in the corners.
    FixBot'a Sor
    Yorum Ekle
  13. Dell Inspiron 6000 Screen Replacement: adım 13, 2 resimden 1. Dell Inspiron 6000 Screen Replacement: adım 13, 2 resimden 2.
    • Insert the plastic opening tools between the screen holders.
    • Go completely around the screen, separating the screen holders with the plastic opening tools.
    FixBot'a Sor
    Yorum Ekle
  14. Dell Inspiron 6000 Screen Replacement: adım 14, 2 resimden 1. Dell Inspiron 6000 Screen Replacement: adım 14, 2 resimden 2.
    • Remove 12 4mm #00 Philips screws at the perimeter of the screen.
    FixBot'a Sor
    Yorum Ekle
  15. Dell Inspiron 6000 Screen Replacement: adım 15, 2 resimden 1. Dell Inspiron 6000 Screen Replacement: adım 15, 2 resimden 2.
    • Gently lift the screen from the holder.
    • Do not touch the copper part of the bottom side of the screen.
    FixBot'a Sor
    Yorum Ekle
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Jacob DeWar
563 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 11-1, Blackwell Fall 2014 USF Tampa, Team 11-1, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S11G1
5 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 3,075
