Ana içeriğe geç
Dell Inspiron 600m Hard Drive Replacement
Neye ihtiyacın var
  1. Dell Inspiron 600m Hard Drive Replacement, Battery: adım 1, 3 resimden 1. Dell Inspiron 600m Hard Drive Replacement, Battery: adım 1, 3 resimden 2. Dell Inspiron 600m Hard Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Flip laptop upside down and locate the battery as shown in the images.
    • Push in the tab on the battery and lift up. The battery should detach very easily.
  2. Dell Inspiron 600m Hard Drive Replacement, Hard Drive: adım 2, 1 resimden 1.
    • The hard drive is located here.
  3. Dell Inspiron 600m Hard Drive Replacement: adım 3, 1 resimden 1.
    • Use a #00 screwdriver to remove the single screw located in the center of the hard drive cover.
  4. Dell Inspiron 600m Hard Drive Replacement: adım 4, 1 resimden 1.
    • Pull the hard drive tray directly away from the computer. The tray should slide out easily.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Todd
146 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-40, Forte Spring 2011 Cal Poly, Team 10-40, Forte Spring 2011 üyesi
CPSU-FORTE-S11S10G40
5 Üyeler
8 adet Kılavuz yazıldı
2 Yorum
What size is the hard drive, you know, to buy a new one?
Ethan White - Yanıt
Is it a sata drive compatible or pata? It’s older and most laptops from that year hadn't converted to sata hdd.
physicsguy - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 31
Her zaman: 17,218
