Giriş
This guide will walk you through how to replace the LCD screen on your Dell Inspiron 600m. You will need a Philips #00 screwdriver, an anti-static wrist strap, and a wedge type tool such as a flat-head screwdriver or the IFixit Opening Tool to complete this guide.
Neye ihtiyacın var
Flip laptop upside down and locate the battery as shown in the images.
Push in the tab on the battery and lift up. The battery should detach very easily.
Using fingernails or a spudger, push any direction on the rubber dots to remove them from the plastic cover.
Underneath each rubber dot will be a screw. Remove these screws with the Phillips #00 screwdriver.
4 farklı kişi bu kılavuzu tamamladı.
