Ana içeriğe geç
Dell Inspiron 6400 keyboard Replacement
Neye ihtiyacın var
  1. Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: adım 1, 3 resimden 1. Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: adım 1, 3 resimden 2. Dell Inspiron 6400 keyboard Replacement, replacing Keyboard: adım 1, 3 resimden 3.
    • Turn over laptop .Remove battery from laptop by pushing the two tabs are highlighted in blue. Place the battery off to the side.
  2. Dell Inspiron 6400 keyboard Replacement: adım 2, 3 resimden 1. Dell Inspiron 6400 keyboard Replacement: adım 2, 3 resimden 2. Dell Inspiron 6400 keyboard Replacement: adım 2, 3 resimden 3.
    • Remove the 3 screws highlighted in red that secure the keyboard to the case using the screwdriver with largest phillips head in the box. Make
  3. Dell Inspiron 6400 keyboard Replacement: adım 3, 3 resimden 1. Dell Inspiron 6400 keyboard Replacement: adım 3, 3 resimden 2. Dell Inspiron 6400 keyboard Replacement: adım 3, 3 resimden 3.
    • Turn the device right side up and open the device to view the keyboard.
    • Remove the keyboard away from the case ,using a plastic spudger if necessary.
    • The keyboard will still be attached to the motherboard by a ribbon cable.
  4. Dell Inspiron 6400 keyboard Replacement: adım 4, 3 resimden 1. Dell Inspiron 6400 keyboard Replacement: adım 4, 3 resimden 2. Dell Inspiron 6400 keyboard Replacement: adım 4, 3 resimden 3.
    • Replace the new keyboard with plastic spudger.
    • The keyboard will have to be attached to the motherboard by a ribbon cable.
    • Snapped the keyboard back in place.
  5. Dell Inspiron 6400 keyboard Replacement: adım 5, 3 resimden 1. Dell Inspiron 6400 keyboard Replacement: adım 5, 3 resimden 2. Dell Inspiron 6400 keyboard Replacement: adım 5, 3 resimden 3.
    • Flip over the laptop
    • Put the screws back in laptop
  6. Dell Inspiron 6400 keyboard Replacement: adım 6, 2 resimden 1. Dell Inspiron 6400 keyboard Replacement: adım 6, 2 resimden 2.
    • Place the battery and lock it into place
Sonuç
kempc8
899 İtibar
7 adet Kılavuz yazıldı
Ekip
K and K Fixit K and K Fixit üyesi
Business
1 Üye
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 13
Her zaman: 934
