Ana içeriğe geç
Dell Inspiron 700m Hinge Cover Replacement
Neye ihtiyacın var
    1. Dell Inspiron 700m  Hinge Cover  Replacement, Removing battery: adım 1, 1 resimden 1.
      • Remove the battery by sliding and holding the battery release latch.
      • Make sure your computer is turned off and unplugged.
      FixBot'a Sor
      Yorum Ekle
    2. Dell Inspiron 700m  Hinge Cover  Replacement, Open display: adım 2, 1 resimden 1.
      • Open the display 180 degrees.
      FixBot'a Sor
      Yorum Ekle
    3. Dell Inspiron 700m  Hinge Cover  Replacement, Removing Display: adım 3, 1 resimden 1.
      • Use a plastic flat screwdriver to slide the hinge caps away from the computer.
      FixBot'a Sor
      Yorum Ekle
      • Detach the two display latches on the back of the computer.
      FixBot'a Sor
      Yorum Ekle
      • Use plastic flat screwdriver to carefully pry up the latches on either side of the hinge cover
      FixBot'a Sor
      Yorum Ekle
      • Carefully, lift the hinge cover from the main unit and remove it from the main unit.
      FixBot'a Sor
      Yorum Ekle
Sonuç
irlanda
12.761 İtibar
2 adet Kılavuz yazıldı
Ekip
RampUP America, Inc. RampUP America, Inc. üyesi
Community
45 Üyeler
12.124 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 456
