Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Unplug the power cable.
Flip the 700m over and remove the battery.
Slide the battery release switch toward the center of the 700m, and then pull the battery free from the back.
Remove the two Phillips screws securing the RAM cover.
Remove the RAM cover and set it aside.
Two clips secure the RAM module in place, one on each side. Using your fingers, spread the clips away from the RAM module.
Lift the RAM module to an angle of about 30 degrees and slide it out.
Flip the 700m over and swing the screen all the way open until it lays flat.
Beginning from the left side, use the flat end of a spudger to gently pry up the plastic trim that runs along the top edge of the keyboard. Remove the trim.
Tilt the top of the keyboard up at an angle, and gently push the keyboard toward the back of the 700m, freeing the tabs along the bottom.
Tilt the bottom of the keyboard up at an angle.
Use the pointed end of a spudger to disconnect the keyboard ribbon cable by pushing open the clips on either side.
Remove the keyboard and set it aside.
Remove the two Phillips screws securing the inner RAM cover.
Tilt the right side of the RAM cover up at an angle and pull it free.
4 farklı kişi bu kılavuzu tamamladı.
