Ana içeriğe geç
Dell Inspiron 7306 P125 Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 7306 P125 Battery Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 7306 P125 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Turn off the laptop with the power button and close it.
    • Disconnect any power sources from the laptop.
  2. Dell Inspiron 7306 P125 Battery Replacement: adım 2, 2 resimden 1. Dell Inspiron 7306 P125 Battery Replacement: adım 2, 2 resimden 2.
    • Use the Phillips #00 screwdriver to remove the seven M2x4 screws from the back panel of the laptop.
  3. Dell Inspiron 7306 P125 Battery Replacement: adım 3, 3 resimden 1. Dell Inspiron 7306 P125 Battery Replacement: adım 3, 3 resimden 2. Dell Inspiron 7306 P125 Battery Replacement: adım 3, 3 resimden 3.
    • Grab a corner of the back cover or use a spudger to lift the cover.
    • Pull the cover up around the edges until it is completely removed.
  4. Dell Inspiron 7306 P125 Battery Replacement: adım 4, 2 resimden 1. Dell Inspiron 7306 P125 Battery Replacement: adım 4, 2 resimden 2.
    • Remove the three tapes on the left, middle, and right of the battery.
  5. Dell Inspiron 7306 P125 Battery Replacement: adım 5, 3 resimden 1. Dell Inspiron 7306 P125 Battery Replacement: adım 5, 3 resimden 2. Dell Inspiron 7306 P125 Battery Replacement: adım 5, 3 resimden 3.
    • Remove the three M2x3.5 screws that have a screw icon above them with the Phillips #00 screwdriver
    • Do not interact with the object located to the left of the middle screw.
  6. Dell Inspiron 7306 P125 Battery Replacement: adım 6, 2 resimden 1. Dell Inspiron 7306 P125 Battery Replacement: adım 6, 2 resimden 2.
    • Pull the battery cable towards the direction of the opening.
    • Do not pull the cable upwards.
  7. Dell Inspiron 7306 P125 Battery Replacement: adım 7, 3 resimden 1. Dell Inspiron 7306 P125 Battery Replacement: adım 7, 3 resimden 2. Dell Inspiron 7306 P125 Battery Replacement: adım 7, 3 resimden 3.
    • Insert the new battery. Align the holes of the screwdriver with the center object.
    • Apply the tape from the wires to the battery once more.
    • Ensure that the cover snaps into place when closing the back cover.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Arturo Gonzalez
172 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 75
Her zaman: 659
