Ana içeriğe geç
Dell Inspiron 7486 Chromebook Battery Replacement
Neye ihtiyacın var
  1. Dell Inspiron 7486 Chromebook Battery Replacement, Battery: adım 1, 2 resimden 1. Dell Inspiron 7486 Chromebook Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Power off your Chromebook and unplug it from the AC adapter before starting.
    • Remove the seven 6 mm screws securing the base cover with a Phillips #1 screwdriver.
  2. Dell Inspiron 7486 Chromebook Battery Replacement: adım 2, 2 resimden 1. Dell Inspiron 7486 Chromebook Battery Replacement: adım 2, 2 resimden 2.
    • Unscrew the three captive screws with a Phillips #1 screwdriver.
  3. Dell Inspiron 7486 Chromebook Battery Replacement: adım 3, 2 resimden 1. Dell Inspiron 7486 Chromebook Battery Replacement: adım 3, 2 resimden 2.
    • Gently pry the base cover loose at the hinges with a plastic opening tool.
    • Carefully run your fingertips along the edges of the base cover to remove it.
  4. Dell Inspiron 7486 Chromebook Battery Replacement: adım 4, 3 resimden 1. Dell Inspiron 7486 Chromebook Battery Replacement: adım 4, 3 resimden 2. Dell Inspiron 7486 Chromebook Battery Replacement: adım 4, 3 resimden 3.
    • Using a Phillips #0 screwdriver, remove the two 4 mm screws securing the battery cable bracket to the motherboard.
    • Remove the battery cable bracket.
  5. Dell Inspiron 7486 Chromebook Battery Replacement: adım 5, 2 resimden 1. Dell Inspiron 7486 Chromebook Battery Replacement: adım 5, 2 resimden 2.
    • Using a Phillips #0 screwdriver, remove the four 3 mm screws that secure the battery to the motherboard.
  6. Dell Inspiron 7486 Chromebook Battery Replacement: adım 6, 3 resimden 1. Dell Inspiron 7486 Chromebook Battery Replacement: adım 6, 3 resimden 2. Dell Inspiron 7486 Chromebook Battery Replacement: adım 6, 3 resimden 3.
    • Pull the tab on the battery cable to disconnect it from the motherboard.
    • Remove the battery.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
[deleted]
265 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 18
Son 30 gün: 49
Her zaman: 1,266
